How to add the printer Geeetech A10 to Cura
Admin
Post by Admin » Tue Sep 04, 2018 10:08 am
Hi guys! :o
Are you can't find Geeetech A10 on Cura?
Don't worry
Refer to these:
------------------------------ :D --------------------------------------------------
Update:Thanks for @vert's suggestions.
1. We added the G29 for the start code
We added the "G1 Y230 F6000" for the end code( 2019/1/7)
2. We attached the PLA filament profile for Multi_mixer printer(2019/1/23)
3. We set the default filament diameter to 1.75mm and it can work with Cura 4.0(2019/4/7)
4.Thanks for @LisaE‘s suggestions.The profile updated.(2019.4.17)
5. Deleted the "Heating gcode for nozzle/hotbed"in"start code".Added the meshes file.(2019.4.24)
1.Download Profile for Geeetech 3Dprinter
Cura4.0 resources.zip
(158.48 KiB) Downloaded 7067 times
Download the PLA filament profile for A30
Geeetech PLA_1.xml.zip
(930 Bytes) Downloaded 4351 times
2. Unzip the zip file then you will get "resources"folder
3.Copy "resources" to the
Cura installation directory
Default:
C:\Program Files\Ultimaker Cura 4.0
4.Import filament profile
5.Done!Enjoy it!
krismcewan
Re: How to add the printer Geeetech A10 to Cura
Post by krismcewan » Thu Sep 13, 2018 4:54 am
Can you do one for the A10M?
Merrill
Post by Merrill » Sun Oct 21, 2018 1:30 am
Thank you for preparing and sharing this. :D
Trevenator
Post by Trevenator » Mon Oct 29, 2018 7:30 am
Yes can you please do one for the A10M ?
grabejud
Post by grabejud » Fri Nov 23, 2018 3:00 pm
My printer is coming. so it would be great to have the A10M settings for cura
Mocco1301
Post by Mocco1301 » Sat Nov 24, 2018 7:28 pm
:shock:
I did this and now Cura is starting my print too high and/under extruding. Switched back to Repetier Host and no problems at all with same bed level etc.
schlaflosin030
Post by schlaflosin030 » Wed Dec 05, 2018 5:56 am
How to add the Extruder from A10 to Cura????
what is with the Extruder? All entrys are empty in thes Geeetech A10 Driver. :(
Or how can say wher i find a Post with thes answer. ;)
it´s my first time in 3d-Printing and i´m an absolutly beginner, but i hope that ist will be better with your help ;)
than´s and have a nice time
Rogeralcon
Post by Rogeralcon » Tue Dec 25, 2018 3:39 am
Warning: this file only works for PLA :!: Yesterday I tried to print PETG, but initial gcode lowered the temperature to 200 * C without permission. :idea: This file was the Problem.
aamulk
Post by aamulk » Sun Jan 13, 2019 4:26 pm
Is there going to be a file made for the A10M? I would think that shouldnt be a problem for the developers especially when it is a recommended program!! I tried the custom route as suggested in the manual but the latest version of Cura does not give the FDM printer option only the FFM, as a result Cura does not seem to communicate with the printer.
bensnapper
Post by bensnapper » Sun Dec 01, 2019 7:55 pm
Hi, brand new to the world 3D printer. I just got the A10 and trying to set up it's profile on Cura for it (Cura 4.4) and when i put the resource from the zip folder here into the cura folder in Programs, all the other printers appear but not the A10. Any suggestions?
when i look in the folder I see it there but Cura doesn't seem to pick it up in the list of printers.
Thank you
