partscooling-fan not working at all
SebastianM
Post by SebastianM » Thu Nov 15, 2018 2:46 pm
Good morning from Germany!
Yesterday I received my A10 (new version with filament sensor) and the first print went very good. Unfortunately, my partscooling-fan does not work at all.
Neither when I print the sample gcode (A10_dog.gcode) nor when I set it in the menu to "255" (menu control / temperature / fan).
No reaction from the fan at all...
thx in adavance...
PS: This isnt my first 3d printer, so I know what I am doing :))
Re: partscooling-fan not working at all
Post by _kaktus_ » Thu Nov 15, 2018 4:00 pm
Hello.
So, in the first step I would check the correctness of the connections.
The second step is whether there is a voltage on the fan's cables after the fan has been driven.
Check the 12/24V fan type and compare it with the control voltage.
SebastianM
Post by SebastianM » Fri Nov 16, 2018 12:56 am
ehm... where exactly are the pins for the parts-fan?
SebastianM
Post by SebastianM » Fri Nov 16, 2018 3:58 am
Update: I played a bit with the cables and now it seems to work...
I will keep an eye on it.
thx!
Gingko
Post by Gingko » Fri Nov 16, 2018 10:00 am
Check the slot on the extension board first (seems you got it).
So it might be the poor connection? ;)
Matteo Simioni
Post by Matteo Simioni » Sat Nov 17, 2018 4:12 am
thx in adavance...
Hi SebastianM, I am having exactly the same problem with my A10 that arrived few days ago, can you please tell me exactly how you solved?
Thanks very mutch!
SebastianM
Post by SebastianM » Mon Nov 19, 2018 4:47 pm
mathiaskahn
Post by mathiaskahn » Mon Dec 17, 2018 7:23 am
Exact same problem here, with new A10 (GT2560 v3.0 mainboard).
Proposed solution (play with cable) does not solve.
Any idea ?
SebastianM
Post by SebastianM » Fri Dec 21, 2018 6:30 am
I got a replacement Fan...
