Greetings,
I use SketchUp 8.0, to design a RC wheel, export as .STL and .OBJ.
Import to Repetier Host and Slice with CuraEngine.
After repair the object, the wheel show a top cover.
How remove or not print this unnecessary top cover?
I try mark "Spiralize contour", not work.
Someone can help-me?
Best regards.
Unnecessary top cover
- 1.jpg (20.87 KiB) Viewed 28424 times
- 2.jpg (24.99 KiB) Viewed 28424 times
- 3.jpg (27.12 KiB) Viewed 28424 times
- 4.jpg (24.52 KiB) Viewed 28425 times
My printer is: Geeetech prusa I3 A Pro 3D
Re: Unnecessary top cover
Hello.
You wrote:
What was the reason for this operation
Maybe it introduces a problem.
Thank for your reply _Kaktus_.
The message showed is: Than I try slice without repair.
Not work.
Not work.
Would you agree to share your model with us before repair?
I will see what can be done.
Check it out now.
Wow!
Perfect! What it's mistery?
I imported in Tinkercad, set the position to the grid, and did the export.
Sometimes I ignored this message, and printed without repair.
