Extruder not working
Re: Extruder not working
Post by _kaktus_ » Mon Oct 29, 2018 1:34 pm
Pusilanime wrote:
Mon Oct 29, 2018 4:50 am
When I start printing, there is no problem, it works all right, but after around 10 minutes the extruder starts to make a clicking sound.
It happends every time I try to print and I have to push the filament manually to allow printing to continue.
I´ve checked the board and the extruder has 1.1V
There is also no cloggs on the extruder.
What could be the problem?
You probably have a leveling problem.
Also check that the X axis linear guides are parallel to the heat bed surface.
Pusilanime
Post by Pusilanime » Tue Oct 30, 2018 6:04 am
I measured it and it's perfectly aligned..
I tried with a 190-210 °C range (PLA)
Another thing to consider?
Post by _kaktus_ » Tue Oct 30, 2018 1:16 pm
If your mechanisms are perfectly assembled and all components are perfectly parallel and perpendicular, then two things come to my mind for consideration. :roll:
  1. You can try to increase the spring pressure in the extruder's mechanism.
  2. The nozzle or transport route in the Hot End element can be partially clogged.
You can also use this guide to try to solve the problem yourself.
:D
masternlpngatpro@gmail.com
Post by masternlpngatpro@gmail.com » Wed Nov 14, 2018 1:11 am
venum wrote:
Fri May 05, 2017 10:49 pm
Bonjour
J'ai un problème , sa fais quelque moi que jais acheter un imprimante 3 d Acrylic Reprap Prusa I3 Pro B mais voilà quand j'ais reçu mon imprimante le moteur de l'extrudeur refusée de tourner donc j'ai contacté le service geeetech qui ma renvoyer une carte mère qui a marcher comme il faut 3 fois et d'un coup en plaine impression un bip sonore retenti donc j'un couper l'imprime , je les rallumer et vérifiée que tout fonctionner mais à nouveau le moteur de l'extrudeur refuse de marcher j'ais tout tentée .donc je pence que la carte mère a encore cramée ?
Que faire je doit acheter une carte mère ?
Post by William » Wed Nov 14, 2018 9:32 am
Bonjour
Maybe he can attach the photos then we can get more detail from it.
klotzii
Post by klotzii » Thu Nov 29, 2018 6:41 pm
Hi!
Is there a step-by-step guide to set the right extruder tension for the A10M extruder? One motor makes very strange noises, changed the cables from E0 to E1 and it doesn´t change anything, still the same noises on the same motor.
What motor-type is it in this special case or do you have a link? (Just in case i want one for spare)
Best regards
klotzii
Post by William » Fri Nov 30, 2018 9:34 am
klotzii
Post by klotzii » Tue Dec 04, 2018 10:15 pm
Well, thx for the Link, but on my Stepper is "42SHD0227-24B" engraved on the Backside. But I can´t find this type anywhere...
Also the mechanic of the extruder can´t be found anywhere... :-(
Post by William » Wed Dec 19, 2018 10:01 am
You need to contact the sales at first.
They can give you more info of it ;)
Dr_Schmal
Post by Dr_Schmal » Sat Mar 02, 2019 6:16 pm
sadandres wrote:
Wed Jun 29, 2016 12:34 pm
I inspect the voltage, and I find that the A4988 at extruder side measures 0 volt between potentiometer and GND, and 5 volt between VDD and GND. I exchange with any axis to test, and now that axis only moves in one direction. I assume that my A4988 is bad, so… I'm looking for a replacement. I am right?
Thanks to all.
Did you tried to disable cold extrusion checking? ;) (Enter "M302 P1" in EasyPrint -> Control -> G-Code)
Sometimes I had issues that the extruder is not enabled when I press "E-" in EasyPrint :roll:
Users browsing this forum: No registered users and 25 guests
