Bad Base Plate Guide
bernte_one
Post by bernte_one » Fri Aug 31, 2018 3:34 pm
I have received one of these defective A10. The aluminum profile of the guide of the base plate has a dent or notches. The rolls stay about every 7cm.
It is not my job to rebuild that somehow. Is there a corresponding spare part or should I send the goods back, is there proportionate money back?
I got mine Printer over ebay seller from Czech.
bernte_one
Re: Bad Base Plate Guide
Post by bernte_one » Mon Sep 03, 2018 12:01 am
i made a video to show the problem
https://www.youtube.com/watch?v=uhd-zCXI1BM
:o
zonalimitatore
Post by zonalimitatore » Tue Sep 04, 2018 1:37 am
You need to adjust the 4 wheels. From video seem to be too hard and not in axys
bernte_one
Post by bernte_one » Tue Sep 04, 2018 8:07 pm
Nothing to adjust. Drillholes are misplaced. Bed ist Not plane. I can only adjust between loose and wobbly or hard and stiff.
zonalimitatore
Post by zonalimitatore » Wed Sep 05, 2018 2:13 am
doesn't matters if there is a light there. The important is the bed.
I notice le screw on left are not perpendicular.
You have to adjust these left side screw to be perpendicular,and after the right screw and set up with eccentrical
bernte_one
Post by bernte_one » Wed Sep 05, 2018 3:20 pm
:lol:
you can write it thousand time, but there is nothing to adjust
the drill hole for the wheel axis are misplaced several Millimeter
if i tighten it the bed slide plate is mor like a bow, but not plane
in result the the for adjusting screws for bed Level are Standing more and more non vertical
---------- heatbed
/ \ screws
--------------- slider plate
here i can Show the result of hole fail construction, a build precision i can get when cutting part from Hand by myself
https://www.youtube.com/watch?v=D9KSf5NXVHo
Post by _kaktus_ » Wed Sep 05, 2018 3:31 pm
You have to remember one thing.
Manual movement of the mechanisms is very dangerous for electronics, even when the power supply is switched off.
bernte_one
Post by bernte_one » Wed Sep 05, 2018 3:32 pm
the next joke i found yesterday after installing all, that the Extruder end stop is too far away on the left side
so Auto Zero will place the Extruder left besides the bed (5mm +/-) :?
you can´t Mount the endstop more right, because it is fixed on a plate from stepper motor :roll:
so only solution i can do is to place a spacer between endstop Switch and the Extruder carrier to Bridge 5mm+/- :cry:
so from that what i have compred on YouTube i got the crappiest a10 pinter for now
These hole supporters from YouTube which got These Printer for free or other Special condition should be shame themself
they got Special checked and best made Printers for Promotion
but the normal user got frustrating fail production?
bernte_one
Post by bernte_one » Wed Sep 05, 2018 3:37 pm
and how did you Level your bed? :lol:
and know the fact, but manuel say: Switch on, go to menue, disable stepper, and adjust bed on several Points....
better you tell this manufacturer, that they add a kill Switch for the stepper power line for leveling procedure?
zonalimitatore
Post by zonalimitatore » Wed Sep 05, 2018 9:15 pm
