Me Creator 2: Home- and Origin-Point
hotten64
Post by hotten64 » Sun Jul 30, 2017 2:31 am
I am a newbie to 3D-printing and have bought a Me Creator 2. I have a question about before I started printing with SD-Card.
The user manual tells me:
“Home position is in the right back corner of the printing platform.“
This is the same point I get with “Auto Home“ in Me creator 2 “Prepare“ menu.
With Repetier-Host: "Note: the origin point is the left front corner of the platform when printing. So when the printer is at home position, the coordinates of X/Y axis are: X=160mm, Y=160mm, Z=0mm."
Now my questions:
- Must I before every printing calibrate with Repetier-Host the origin point at the left front corner manually, no matter I use USB or SD-Card?
- Can I save this settings anyway to Repetier-Host?
- Is there a way to automate this with modified g-code and Me Creator 2 get the movement to origin point from g-code without “homing“ in Repetier-Host manually?
With regards
hotten64
Re: Me Creator 2: Home- and Origin-Point
Post by William » Mon Jul 31, 2017 9:27 am
It is ok ,you need not calibrate the origin point to the right back corner ,because the printer will do it automatically before starting printing.
Thierry44
Post by Thierry44 » Sat Nov 18, 2017 2:56 am
I've got something strange, when Iask the printer to go home it tells me X 175 Y 165 Z0.
is it normal ?
Thank you
Thierry
Post by William » Mon Nov 20, 2017 11:35 am
Have you enabled 3D touch functionality in the firmware?
Thierry44
Post by Thierry44 » Sat Nov 25, 2017 2:30 am
hello
I don't think so. I've never been told about this. How can I do this. The came with the firmware loaded.
Thank you
Thierry
MucMoe
Post by MucMoe » Wed Jul 11, 2018 3:14 pm
Hello, I also have a Me Creator 2 since yesterday. now I also have the problem that my home position is at X175, Y163, Z0. how can I solve the problem? I already tried that with the offset in repetierhost, and also starting x10 and y10 and then set home offset. but that doesn't work.
please help me :-)
Gingko
Post by Gingko » Thu Jul 12, 2018 5:14 pm
please help me :-)
You can download the firmware from this link: viewtopic.php?f=20&t=17046
Try to edit the code:
Code: Select all
// Travel limits after homing
#define X_MAX_POS 175
#define X_MIN_POS 0
#define Y_MAX_POS 165
#define Y_MIN_POS 0
#define Z_MAX_POS 161
#define Z_MIN_POS 0
to:
Code: Select all
#define X_MAX_POS 160
#define X_MIN_POS 0
#define Y_MAX_POS 160
#define Y_MIN_POS 0
#define Z_MAX_POS 160
#define Z_MIN_POS 0
Then re-burn the firmware, hope it will be work.
Users browsing this forum: justinc1981 and 43 guests
