Radial fan problem MeCeator2
Bushido77
Post by Bushido77 » Wed Apr 26, 2017 5:30 am
Hi , I have a new MeCreator 2 and I'm having trouble getting the radial fan working . The fan works fine but it doesn't turn on during a print, Even if I select fan always on in slic3r or using repeatier-host. Any suggestions would be appreciated,
Bushido77
Re: Radial fan problem MeCeator2
Post by Bushido77 » Wed Apr 26, 2017 6:04 am
All other functions work by sending Gcode directly to the printer, except fan.
I've removed the fan and tested it and also checked the connections
Post by William » Thu Apr 27, 2017 11:02 am
Hi,could you take video about the situation that fan don't work?I think the port of fan in the Extruder development board may need to be resoldered.
Bushido77
Post by Bushido77 » Thu Apr 27, 2017 2:16 pm
No sense making a video. Its quite simple the Radial fan of which there is one, is not working. Do you have a schematic of the GT2560 Rev B so I can check it ?
I'm going to send this printer back for a refund ,
radial fan.jpg (40.29 KiB) Viewed 6376 times
