Hy,
I am Simon from Austria and i print normally with a bq Witbox 2,
but some weeks ago i bought a Rostock 301 on Aliexpress, because of the Mix Features,
but i have some Troubles with it and i don't know the right Settings and i would be glad for help!
I apologize in advance for my bad English
Questions:
1. How to set exactly the middle of the platform?
2. What do the abbreviations in the Settings mean?
-> Amax E? V.- jerk? Effector offs? Carriage Offs? Delta Radius) Print Radius?.... What would be the correct settings?
3. How many Esteps/mm? I use this Gearbox: http://www.omc-stepperonline.com/gear-r ... -p-40.html
Simon
Rostock 301 Settings
- Bild4.jpg (57.85 KiB) Viewed 14748 times
- Bild3.jpg (42.3 KiB) Viewed 14748 times
- Bild2.jpg (53.71 KiB) Viewed 14748 times
- Bild1.jpg (55.11 KiB) Viewed 14748 times
Re: Rostock 301 Settings
Hi,SimonFriggy wrote:Hy,
Questions:
Simon
About the settings,just keep them the default values.
Don't modify them arbitrarily.
Hy Cup,
OK i've done it!
But how about the other Questions?
Diagonal Rod is now 188, i've measured 200!?
Simon
OK i've done it!
Simon
Hello Simon Friggy,
Bonjour Simon Friggy,
Je suis moi aussi nouveau avec l'imprimante comme et en attente de réponses de la part du personnel de Geeetech.
Voici une transcription de la structure des menus de l'écran LCD de l'imprimante 301 qui inclut mes paramètres actuels :
Comme je débute avec les imprimantes 3D, je ne peux vous aidez pour les explications des différent paramètre, car je suis moi-même à la recherche des textes explicatifs, ma je ne trouve presque rien et Geeetech ne répond pas à nos demandes d'informations et des détails sur leurs produits !
Cordialement,
L'ami René
Hello Simon Friggy,
I am also new with the printer as and waiting for answers from Geeetech staff.
Here is a transcript of the menu structure of the 301 LCD screen that includes my current settings:
As I start with the 3D printers, I can not help you with the explanations of the different settings, because I am looking for explanatory texts, but I can not find anything and Geeetech does not respond to our requests for information And details on their products!
Cordially,
Friend René
Ma plaque chauffante d'impression en aluminium n'est pas plate, elle est concave, c'est la raison du « Delta Radius : 94.0 ».- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
Geeetech 301 Configuration du micrologiciel.txt
Prepare ->
- Disable Steppers
- Auto Home
- Preheat PLA
- Preheat ABS
- Cooldown
- Move Axis ->
-- Move 10mm ->
--- Move X ->
---- X : 0.0
--- Move Y ->
---- Y : 0.0
--- Move Z ->
---- Z : 0.0
-- Move 1mm ->
--- Move X ->
---- X : 0.0
--- Move Y ->
---- Y : 0.0
--- Move Z ->
---- Z : 0.0
--- Extruder 0 ->
---- Extruder 0 : 0.0
--- Extruder 1 ->
---- Extruder 1 : 0.0
--- Extruder 2 ->
---- Extruder 2 : 0.0
-- Move 0.1mm ->
--- Move X ->
---- X : 0.0
--- Move Y ->
---- Y : 0.0
--- Move Z ->
---- Z : 0.0
--- Extruder 0 ->
--- Extruder 1 ->
--- Extruder 2 ->
Control ->
- Temperature ->
-- Nozzle : 0
-- Bed : 0
-- Fan speed : 0
-- Autotemp : Off
-- Min : 215
-- Max : 250
-- Fact :
-- N-PID ->
--- N-PID-P : +0608.05
--- N-PID-I : +0036.63
--- N-PID-D : +2709.19
-- B-PID ->
--- B-PID-P : +0369.61
--- B-PID-I : +0054.13
--- B-PID-D : +0602.87
-- Preheat PLA Conf ->
--- Fan speed : 0
--- Nozzle : 215
--- Bed : 70
-- Preheat ABS Conf ->
--- Fan speed : 0
--- Nozzle : 240
--- Bed : 95
- Printer Setting ->
-- X Max : 300
-- X Min : 0
-- Y Max : 300
-- Y Min : 0
-- Z Max : 228
-- Z Min : 0
-- Home X : Max
-- Home Y : Max
-- Home Z : Max
-- X Motor Dir : True
-- Y Motor Dir : True
-- Z Motor Dir : False
-- E Motor Dir : True
-- E1 Motor Dir : True
-- E2 Motor Dir : True
-- XmaxEndstop ->
--- Logic level : High
--- Status : NC
-- XminEndstop ->
--- Status : NC
-- YmaxEndstop ->
--- Status : NC
-- YminEndstop ->
--- Status : NC
-- ZmaxEndstop ->
--- Status : NC
-- ZminEndstop ->
--- Status : NC
-- Delta ->
--- Segments/sec : 200
--- Diagonal Rod : 197
--- Smooth offs : 160
--- Effector offs : 33
--- Carriage offs : 33
--- Delta Radius : 94.0
--- Print Radius : 90
-- Motion ->
--- Z offset : 0.00
--- Accel : 5000
--- Vx-jerk : 20
--- Vy-jerk : 20
--- Vz-jerk : 20
--- Ve-jerk : 5
--- Vmax X : 400
--- Vmax Y : 400
--- Vmax Z : 400
--- Vmax E : 1000
--- Vmin : 5
--- VTrav min : 5
--- Amax X : 5000
--- Amax Y : 5000
--- Amax Z : 5000
--- Amax E : 800
--- A-retract : 3000
--- Xsteps/mm : 80.26
--- Ysteps/mm : 80.26
--- Zsteps/mm : 80.26
--- Esteps/mm : 95.00
--- Home speed X : 360
--- Home speed Y : 360
--- Home speed Z : 360
-- Store Memorie
-- Restore Default
-- Version
--- Firmeware 1.0.02
- Mixer ->
-- Filament 0 : 100%
-- Filament 1 : 0%
-- Filament 2 : 0%
-- OFP ->
--- OFP Max : 100%
--- OFP Min : 0%
--- Store Memory
-- Temptates ->
--- Temptates 1
--- Temptates 2
--- Temptates 3
--- Temptates 4
--- Temptates 5
--- Temptates 6
--- Temptates 7
--- Temptates 8
--- Custom 1
--- Custom 2
--- Custom 3
--- Custom 4
--- Custom 5
--- Custom 6
-- Custum ->
--- Custom 1 Conf ->
---- Start Percent : 0%
---- End Percent : 100%
---- Start Height : 0.0
---- End Height : 100.0
---- Store Memory
--- Custom 2 Conf ->
---- Store Memory
--- Custom 3 Conf ->
---- Store Memory
--- Custom 4 Conf ->
---- Store Memory
--- Custom 5 Conf ->
---- Store Memory
--- Custom 6 Conf ->
---- Store Memory
No SD Card
SD Card ->
Cordialement,
L'ami René
Hello Simon Friggy,
My aluminum hotplate is not flat, it is concave, this is the reason for the "Delta Radius: 94.0".- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
Prepare ->
- Disable Steppers
- Auto Home
- Preheat PLA
- Preheat ABS
- Cooldown
- Move Axis ->
-- Move 10mm ->
--- Move X ->
---- X : 0.0
--- Move Y ->
---- Y : 0.0
--- Move Z ->
---- Z : 0.0
-- Move 1mm ->
--- Move X ->
---- X : 0.0
--- Move Y ->
---- Y : 0.0
--- Move Z ->
---- Z : 0.0
--- Extruder 0 ->
--- Extruder 1 ->
--- Extruder 2 ->
-- Move 0.1mm ->
--- Move X ->
---- X : 0.0
--- Move Y ->
---- Y : 0.0
--- Move Z ->
---- Z : 0.0
--- Extruder 0 ->
--- Extruder 1 ->
--- Extruder 2 ->
Control ->
- Temperature ->
-- Nozzle : 0
-- Bed : 0
-- Fan speed : 0
-- Autotemp : Off
-- Min : 215
-- Max : 250
-- Fact :
-- N-PID ->
-- B-PID ->
--- Fan speed : 0
--- Nozzle : 215
--- Bed : 70
--- Fan speed : 0
--- Nozzle : 240
--- Bed : 95
-- X Max : 300
-- X Min : 0
-- Y Max : 300
-- Y Min : 0
-- Z Max : 228
-- Z Min : 0
-- Home X : Max
-- Home Y : Max
-- Home Z : Max
-- XmaxEndstop ->
--- Status : NC
-- XminEndstop ->
--- Status : NC
-- YmaxEndstop ->
--- Status : NC
-- YminEndstop ->
--- Status : NC
-- ZmaxEndstop ->
--- Status : NC
-- ZminEndstop ->
--- Status : NC
-- Delta ->
-- Motion ->
--- Z offset : 0.00
--- Accel : 5000
--- Vx-jerk : 20
--- Vy-jerk : 20
--- Vz-jerk : 20
--- Ve-jerk : 5
--- Vmax X : 400
--- Vmax Y : 400
--- Vmax Z : 400
--- Vmax E : 1000
--- Vmin : 5
--- VTrav min : 5
--- Amax X : 5000
--- Amax Y : 5000
--- Amax Z : 5000
--- Amax E : 800
-- Store Memorie
-- Restore Default
-- Version
- Mixer ->
-- Filament 1 : 0%
-- Filament 2 : 0%
-- OFP ->
--- OFP Max : 100%
--- OFP Min : 0%
--- Store Memory
-- Temptates ->
--- Temptates 1
--- Temptates 2
--- Temptates 3
--- Temptates 4
--- Temptates 5
--- Temptates 6
--- Temptates 7
--- Temptates 8
--- Custom 1
--- Custom 2
--- Custom 3
--- Custom 4
--- Custom 5
--- Custom 6
-- Custum ->
---- Store Memory
---- Store Memory
---- Store Memory
---- Store Memory
---- Store Memory
---- Store Memory
No SD Card
SD Card ->
Cordially,
Friend René
One for all and all for one !
Hy Rene,
My settings are almost the same!
For: Delta, Diagonal Rod I have 200.
Yesterday I set and tried many things, the 3D print now almost fits.
My Planetary Gearboxes have a good torque and now the Filament supply works,
but i dont know how much steps/mm to set, so i multiplied a factor in Slicer!
At the speeds indicated by geeetech the axis loses way (steps), so reduce the Speeds!
I tried now, print with 20mm and a travel Speed from 40mm.
With my Witbox 1 and Witbox 2 i could print 90mm/s with the right Filament,
but they were also more expensive, Nevertheless the data from geeetech do not agree!!!
Simon
Simon
Hello Simon Friggy,
Je ne suis pas certain de bien comprendre ce que vous écrivez. Je vous traduis en français avec Google Traducteur. Si vous avez des sauts de pas des moteurs pas-à-pas, est-ce que vous avez procédé à l'ajustement de la force des moteurs avec le potentiomètre des pilotes de moteur ?
Cordialement,
L'ami René
Hello Simon Friggy,
I'm not sure I understand what you're writing. I translate you in French with Google translator. If you have not hopping step-by-step motors, is that you have made the adjustment of motor power with the potentiometer motor drivers?
Cordially,
Friend René
Cordialement,
L'ami René
Hello Simon Friggy,
Cordially,
Friend René
Hy Rene,
I tried to solve the Problem with the Extrusion Multiplier, i changed to 3,
because i dont know how many steps per mm.
I think it needs a better Motor with more torque for the axis too!
maybe this one: http://www.omc-stepperonline.com/3d-pri ... -p-17.html
Simon
Simon
- Filament Multiplikator.JPG (49.5 KiB) Viewed 14706 times
This one is the original Stepper Motor for the axis and has got 500mNm: https://de.aliexpress.com/store/product ... 53889.html
This one, would have 650mNm and the same Shaft Diameter (5mm): http://www.omc-stepperonline.com/nema-1 ... -p-21.html
Maybe this one from the Extruder could be used, he has 600mNm: https://www.geeetech.com/hybrid-stepper ... p-947.html
Simon
Simon
