William Kwok wrote:Jpriest81 wrote:Hi guys
my problem is similar to those listed but with slight differences. My Pro B started to under extrude in a small part of prints so i took the extruder apart to clean the teeth, seeing no improvement i re wrote the firmware and now the stepper motor for the extruder will not run continuously. It stutters now one step forward then one step back regardless of the direction i tell it to move in. I have tested the motor itself and it displays no fault. Please help with my next step i have run out of ideas.
Kind thanks
Jpriest
Did you upload the right firmware from the official site?
You can take down the fan on extruder to observe the movement when you send a "extrude" command.From "forward then one step back",sounds like it is a clogging...Have you used an ejector?Some more questions:
1.Have you measured the extruder driver's voltage or swapped the driver with another axis?
2.How about extruding by hand now?Did it extrude normally?
Thanks for your fast reply William.
I have downloaded the drivers from this exact site
i have also removed the fan from the extruder so as to view the action of the motor and even with no filament loaded the same back forward movement pattern is observed.
having checked your numbered questions
1. I don't have a meter to measure the voltage right now however, having swapped the motor with the x axis the motor then operates normally.
2. I hope i am correct in thinking that 'extruding by hand' means bringing the hot end up to temperature and feeding the filament through the extruder, if this is correct then it extrudes by hand perfectly with no flow speed or consistency issues.
thanks again for your help
