Extruder pulling the PLA
ariel.ramraz@gmail.com
Post by ariel.ramraz@gmail.com » Wed Jun 29, 2016 6:23 pm
I have Geetech 3d Mini desktop printer and sometimes the extruder has difficulties pulling the PLA, is it possible on this printer to add another pulling motor ?
Re: Extruder pulling the PLA
Post by William » Thu Jun 30, 2016 6:08 pm
ariel.ramraz@gmail.com wrote:Hello,
Maybe the driver module's(A4988) driver abilities is not enough.You can increase it by adjusting the potentiometer.Refer the pic below:
Post by ariel.ramraz@gmail.com » Thu Jun 30, 2016 6:16 pm
Thanks for the quick response, I'll try checking it out but not sure this is the issue, sometimes the material comes a bit tight on the wheel and then the printer has difficulties pulling it, I saw in different printers that they have additional motor that help pulling the material.
thanks
Post by William » Fri Jul 01, 2016 12:00 pm
ariel.ramraz@gmail.com wrote:Hi,
thanks
Well,you can check it first and tell me what it goes on.Additionally,one motor is enough cuz it mainly matters the driver abilities.
Good Luck
AnimA
Post by AnimA » Mon Jul 04, 2016 9:15 pm
HI!! I have the same problem! :( i read in some articles that i have to test the voltage (Vref) without the jumper, it is correct? and in this post i read that it is necessary shut off the printer when i am adjusting the potentiometer, is it true?...
AnimA
Post by AnimA » Mon Jul 04, 2016 9:19 pm
HI!! I have the same problem! :( i read in some articles that i have to test the voltage (Vref) without the jumper, it is correct? and in this post i read that it is necessary shut off the printer when i am adjusting the potentiometer, it is true?..
Post by William » Tue Jul 05, 2016 10:51 am
AnimA wrote:HI!! I have the same problem! :( i read in some articles that i have to test the voltage (Vref) without the jumper, it is correct? and in this post i read that it is necessary shut off the printer when i am adjusting the potentiometer, it is true?..
It may not true,if you cut off the power of your printer,then how does the voltage come from?
AnimA
Post by AnimA » Tue Jul 05, 2016 4:01 pm
i done a lot of tests ( printed 5 times the same piece) and i saw that these problems are all times in the same point in every print, it can be the softwate slic3r? now i explain this, slic3r don't work fine now, it crash
frequently and the program close by error! this happened when i modify the setting on slic3r and i saved all, since this moment every day it crash... i tried to print an old GCODE file (that i saved when slic3r worked fine) and the printer printed it without problem (it was very small)... Conclusion: i want to try to delete completly Slic3r and download again it without importation of configuration (clean installation), format my SD. i will write to you if the problem was slic3r or if i didn't solve my problem... Thanks!
