I have problems with my Y-axis (the heat bed). It's drifting slightly, and mostely in the lower layers. This is what a test print looks like when printed in transparent PLA at 200/70 C. If I do a test print and return the nozzle to 0,0,0 the printer is still in calibration, so it's not the stepper loosing steps or something like that. I tried increasing and decreasing the belt tension without any change in result. My own guess is that the threaded rods on the Z-axis are not 100% straight ?
Any suggestions are welcome !
i3 Y-axis drifting
i3 Y-axis drifting
- IMG_0550.JPG (94.54 KiB) Viewed 7668 times
Re: i3 Y-axis drifting
The problem has been solved. I was the wheel inside belt pulley in the y-axis which did not rune totally smooth. I loosend the diagonal screw a little, and that was it.
Hi!!!
I have the same problem too!
Here is the photo showing the displacement...
more close...
Please, if anyone know how to calibrate or solve the problem, we appreciate the contribution!!!
I have a Geeetech Prusa I3 Pro C.
Thanks a los and have a nice day!!!
Leo
more close...
Leo
frovin wrote:The problem has been solved. I was the wheel inside belt pulley in the y-axis which did not rune totally smooth. I loosend the diagonal screw a little, and that was it.
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
