hi everyone
i just finished setting up the kit, had a couple of issues with firmware but it all worked out after some work
now im having a machnical problem with the z motors
the right motor seems to work fine.
the left one is jittering and goes about 2 mm to the right and then back to the left or just stopes moving and makes a humming noise.
i tried running the motors without connecting the rods and it still wont change
any ideas?
btw i did not change anything on the firmware regarding the motors, and i have no expirance working with firmware, electriciry or motors such as this.
would love some advice, or a manual to get me through this rough times
cheers
z axis problems with prusa i3 pro 3in1
Re: z axis problems with prusa i3 pro 3in1
I think this might be the voltage not proper, you can check it as this link shows:
