Hello I have had a gt2560 with 2004 lcd. Gt2560 is brocken so I swapped with a standard ramps/2560. Ai have to buy a standard lcd adapter on ebay for connecting 2004 to ramps. When I connect the lcd ribbon
Printer stop working and on pc I see a mintemp error reached. Lcd doesn't work but is correctly connected.
If I disconnect the lcd printer works normally.
Any idea?
Marco
Lcd problem when connected to ramps
Re: Lcd problem when connected to ramps
which firmware are you using? you need to use the one for ramps board.
Yes the firmware is correct your firmware for rakps board prusa b and it works very well when lcd disconnected.
Lcd is correctly configured in config.h same as gt2560 firmware
solved smart connector connectors are mounted reversed swapped cable now is ok
