Repetier-Host setting on ABS print
animetown9
Post by animetown9 » Thu Mar 19, 2015 7:23 pm
Does anyone here have a good setting for Repetier-Host ABS printing with
Acrylic Geeetech I3 pro and Sanguinololu 1.3a.
zhangxueyou
Re: Repetier-Host setting on ABS print
Post by zhangxueyou » Fri Mar 20, 2015 10:01 am
Please tell me the filament diameter and nozzle diameter.
animetown9
Post by animetown9 » Fri Mar 20, 2015 3:22 pm
Filament 1.75 , nozzle 0.3mm
ABS filament.
zhangxueyou
Post by zhangxueyou » Fri Mar 20, 2015 4:11 pm
slicer settings(1.75-0.3).zip
(715.7 KiB) Downloaded 655 times
johnz
Post by johnz » Wed Nov 11, 2015 11:46 am
How about setting for 1.75 and 0.4 ABS?? Thanks
Mark
Post by Mark » Wed Nov 11, 2015 5:56 pm
you can use the settings above too, just need to change the diameter of the nozlle to 0.4mm.
Also you can refer to the link here to use the repetier host:
http://www.repetier.com/#documantation
Derekchong
Post by Derekchong » Tue Aug 07, 2018 11:19 am
I followed these setting but the print out is horrible. Any good advise?
Abs hollow cube
