Dear GEEETECH staff,
I found out that my power supply has a noisy buzz sound and cannot turn on the 3D printer system I just assembly (Prusa i3).
Could you please refund me for the PSU or send me a new one.
Thank you.
Power Supply Issue.
Power Supply Issue.
Dear GEEETECH Staff,
The PSU which came along with prusa i3 I just assembly has a noisy buzz sound.
Could you refund or send me a new one?
Thank you.
Thank you.
Re: Power Supply Issue.
Please take a picture of wiring of PSU, take a picture of backside.
Wiring the 12V 15A PSU
- Wiring the 12V 15A PSU
- _DSC0060.jpg (147.66 KiB) Viewed 13749 times
Wiring the 12V 15A PSU back side
- Wiring the 12V 15A PSU back side
- _DSC0065.jpg (177.4 KiB) Viewed 13749 times
System does not work after press power button. The PSU also has a noisy buzz sound.
So I change to my LED PSU 12V 10A which look similar.
I wire the cable just exactly like with another one.
It's work!!
The system has activated, but it's power not enough to heat up the extruder head and heat bed.
What I just only did was swap the PSU.
So please do something about this issue.
Does the input voltage equal the AC voltage in your district? There is a switch under the yellow label "110V 220V", please check.
If the input voltage is correct, please contact the customer service.
