hi,
the extruder holder is bending some heating of bed and nozzle. what could be the reason ? is the plastic melting ? i now have tied it with the cable tier. bt looks litle crooked to one side. what is the fix ? if nozzle is not level straight then the print quality will be a problem i guess.
regards
sabeel
Extruder plstic holder is starting to bend downwards
Re: Extruder plstic holder is starting to bend downwards
How bent is it? Can you print model now? The holder can't be melted by hotend.
hi,
pls check thhis , its same and litle to side. so it not good to print
http://www.geeetech.com/forum/viewtopic ... 14&t=16107
A customer shares his method to reshape it. You can refer.
I share my test .
My basket is bent from high temperature many hours.
I remove them from extruder and use "hair-dryers" and flow Hot air in that bent basket around 2-3 minute
and I pull it back to original shape . It can easily to reshape.
and now I put brass plate to fix them top and bottom for reduce bending problem
Hope it will work.
I share my test .
Hope it will work.
Mine is doing the same thing. I've printed 2 items on it
Is there any way to get the STL files for the mount? I would like to print a few for testing.
thanks,
Cheese
![Sad :-(](./images/smilies/icon_e_sad.gif)
thanks,
Cheese
Hi, Cheesebigcheese02 wrote:Mine is doing the same thing. I've printed 2 items on it![]()
thanks,
Cheese
Please leave your email address and your printer type.
Can you get my email from my user account? I prefer not to share it on an open forum....
I have the geetech Prussa I3.
cheese
cheese
Mine is starting to sag too, I noticed some splitting when installing, but it's getting worse, see image:
![Image](http://i.imgur.com/WOtFtYM.jpg)
I'm printing a new one now, but the one pictured below one looks to have more support. I would really appreciate it if you could send me the better one, or provide the .stl file.
My details:
Order NO:20150618012329696
Order Time:2015-06-18 01:23:29
![Image](http://www.geeetech.com/images/v/Geeetech_1geeetechi3pro.jpg)
My details:
Hi, the extruder you have is the improved one, but I think it was printed in PLA, ABS is better.mvdarend wrote:Mine is starting to sag too, I noticed some splitting when installing, but it's getting worse, see image:
My details:
OK, thanks. I'm printing it now, almost finished ![Smile :)](./images/smilies/icon_e_smile.gif)
