Post
by William » Tue Jun 16, 2020 11:12 am
Hi,the motor does not move and the firmware has nothing to do, it may be
1. The problem of the motor itself, you can change the interface to other motors to see if it can move normally.
2. For the problem of the motor wire, you can exchange the motor wire with other axes to see if it can move normally.
3. If there is a problem with the motherboard interface, you can swap the motherboard interface with other axes to see if it can move normally.
4. Drive problems, the same reason, you can exchange checks.
