Is this normal for a A30M? I have stringing Problems.
Any Ideas?
Massiv stringing at A30M
- 916E4239-C672-49BC-B6F8-0194401025D6.jpeg (904.46 KiB) Viewed 11168 times
Re: Massiv stringing at A30M
Black plastics is most problematic one.
Try my profile for A10M, propably you need to change build size and zero position .
For PEI sheet delete line from gcode setup
G1 X12 Y5 Z0 F300 ; stop leaking hotend
otherwise your PEI sheet will have burned hole at zero position.
A10 Slic3r profile: here
Thank you for your answer.
Not really better now.
I will send pictures in a few minutes
as just described unfortunately no improvements.
I have now used Cura, Slic3r and Simplify. Unfortunately the quality of the pictures has gotten worse again. The stringing is almost everywhere identical.
I have now checked several temperatures, several variations of the E-Steps, different filaments and different parameters.
Is there an update for the printer? Are there any settings on the firmware that I don't know?
- IMG_1243-12-01-20-09-16.jpeg (388.41 KiB) Viewed 11141 times
- IMG_1242-12-01-20-09-16.jpeg (339.29 KiB) Viewed 11141 times
- IMG_1241-12-01-20-09-16.jpeg (314.7 KiB) Viewed 11141 times
Hi, You can view your retraction settings:
Reference range: retraction distance: 3-4;
retraction speed 30-40mm / s.
![Smile :)](./images/smilies/icon_e_smile.gif)
I have also tried to use the retraction values to make a change. Unfortunately I did not succeed in improving this.
What astonishes me...why are the E-Steps on the A30M configured to 407 at the factory? Otherwise the value was always around 430?
Are there maybe other parameters wrong?
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Then the retraction setting can be increased,
The retraction distance is set to 6,
Printing speed is slower: 30-60mm / s;
Black supplies are more sensitive to temperature,
You can try to lower the printing temperature by 5-10 °.
It could be other thing - it could be due bad fittings od loose PTFE tube.
I have read in many articles that "stringing" and print quality is a general problem of Geeetech printers.
I have also gone through almost all recommendations of the users. From filament to slicer to parameters.
Everything had a corresponding effect. But never what I expect from a printer in this price range.
To give you a small overview of my prints I have attached a picture.
@Jarda3d: I also use your Slic3r Profil. No Changes
- IMG_1259-17-01-20-09-32.jpeg (321.36 KiB) Viewed 11065 times
I followed a calibration where I printed four 1cm cubes spaced 10mm, 20mm and 40mm apart. I started with a travel speed of 50mm/s and retraction of 0mm. I then printed them increasing the travel speed by 30mm, keeping the retraction at 0mm. Eventually got to 150mm/s and I think this maxed out the speed of the A30M. The stringing was greatly reduced. Then I reprinted increased the retraction in steps of 1mm. I ended up at 5mm retraction where there was no more improvement.
- 30BC15B4-59BF-43CF-8A1F-366781C6EBB9.jpeg (381.12 KiB) Viewed 11017 times
