Patching A20T firmware for 3dTouch
rebornscout
Re: Patching A20T firmware for 3dTouch
Post by rebornscout » Mon Dec 09, 2019 6:08 pm
I'm also in exactly the same situation - there is also another thread with someone else having this issue. Clearly there is an issue that needs to be sorted by Geetech!
Post by William » Mon Dec 09, 2019 6:12 pm
Hi,When you use the Firmware Toolkit to update the firmware,
While uploading the firmware, press and hold the reset button of the printer,
Upload.
rebornscout
Post by rebornscout » Mon Dec 09, 2019 6:27 pm
No, still not working. It still gives the same result as this viewtopic.php?f=117&t=69693
andrevanderweide
Post by andrevanderweide » Mon Dec 09, 2019 11:42 pm
i updated yesterday the firmware with the toolkit because i put a 3d touch on it and is now working i used a usb3 connection on my computer.
Grt André
Last edited by andrevanderweide on Wed Dec 11, 2019 11:50 pm, edited 1 time in total.
Creality Ender 3v2
Creality S10 Pro Marlin 2.0
lmcmulle
Post by lmcmulle » Wed Dec 11, 2019 6:09 pm
When we try to use the firmware uploaded it won’t it forever times out. Some other searching revealed that the perhaps the board doesn’t have a boot loader installed and that’s why no one can patch the firmware. I’m traveling at the moment, But I’m going to try and install a boot loader and then try and patch it. I’ll document the process if I’m successful and share it with everyone @Erica
lmcmulle
Post by lmcmulle » Sat Dec 14, 2019 11:06 pm
Grt André
Can you describe what you did? (did you hold reset as they suggest, did you have to install a bootloader) ...
lmcmulle
Post by lmcmulle » Sat Dec 14, 2019 11:20 pm
Upload.
Can you describe that in a bit more detail william? At which point do you release the reset button, AFTER you've pressed "Upgrade from Local"?
lmcmulle
Post by lmcmulle » Sat Dec 14, 2019 11:23 pm
I'm pretty sure the issue with my printer is that there isn't a bootloader on the board. which is why AVRDude times out constantly. I've seen some videos on how to install a bootloader with a Arduino Uno... @William or someone from Geeetech can we get instructions on how to install a bootloader on this board?
andrevanderweide
Post by andrevanderweide » Sun Dec 15, 2019 12:16 am
Grt André
I did not have to install bootloader ia started the toolkit load the new file local and started the upload and then pres the reset short and it started.
today i leveld the bed and started the first mix color print
Creality Ender 3v2
lmcmulle
Post by lmcmulle » Sun Dec 15, 2019 12:20 am
Thanks man, seems like you got lucky and got a bootloader on yours, Mine is getting returned to amazon monday if I don't get any advice on how to fix this --- sad too as this printer has so much potential.
