Replacing GT2560 A+
IulianM
Replacing GT2560 A+
Post by IulianM » Wed Mar 13, 2019 12:34 am
I own an i3 Pro B printer. At a certain point I shut it off in the evening and very next day did not start at all.
I bought a new GT2560 rev A+ board (identical with the original one).
To upload the firmware I have used the Firmware Toolkit For Geeetech Printer to up-load I3proB_G02_V1.0.04_01.hex.
The display was looking ok. But trying to home the extruder nothing happens. In fact besides the correct information display the printer does nothing.
Then I was thinking to up-grade it to dual extruder so I have changed the PSU, I have added a driver and loaded the I3proC firmware. Nothing again.
I really do not know how to start debugging it. The only idea I have is to change all motor drivers. Do you have any suggestion what should I check and where can I start?
Thank you!
Re: Replacing GT2560 A+
Post by William » Wed Mar 13, 2019 3:38 pm
I think you should check the PSU output voltage at first. ;)
Then check the fuse of the motherboard.
Try to use the multimeter check it.
IulianM
Post by IulianM » Wed Mar 13, 2019 3:54 pm
I have checked the PSU and I get 12V.
The fuses look ok (measured for continuity).
Anything else I can check?
Thank you!
Post by William » Thu Mar 14, 2019 3:14 pm
Do you mean the extruder won't work?
You should heating it to 180C or more then control it move.
It won't move until the temp of it lower than 170C.
Post by William » Thu Mar 14, 2019 3:15 pm
If the all the motor won't move then you should check the endstop wires at first.
IulianM
Post by IulianM » Thu Mar 14, 2019 3:36 pm
I was re-taking yesterday all the measurements. It looks something is bad with either the PSU or with the board. After couple of power-on/power off one of the fuses get burned (the same one). I was trying to connect one by one each connector, powering on and check the fuse; I burned like 10 fuses but still not able to say what is causing this.
Any idea or suggestion?
Thank you!
Post by William » Fri Mar 15, 2019 6:37 pm
I think you should check the A4988 at first.
Try to remove all of it off then check it again
Post by William » Mon Aug 26, 2019 9:24 am
bougti wrote:
Mon Aug 26, 2019 12:25 am
I have changed the driver and the hotend move !!! =)
I have reverse the LCD and SD cable and my screen work ! :)
Now the printer is not calibrate ... For the X Y axis.
Hi, You can check the tightness of your belt;
Check your driver board voltage (0.8-1.2V).
Users browsing this forum: No registered users and 13 guests
