Falesafe
blksilver
Falesafe
Post by blksilver » Thu Apr 08, 2021 8:37 am
Hello all, I was leveling and thought I was having issue with the bltouch I install, so I went and selected failsafe. Now when I try to autohome it goes to the right corner and rises instead homing to the bed. What can I do to rectify this? Thanks
Admin
Re: Falesafe
Post by Admin » Thu Apr 08, 2021 3:47 pm
Hello, have you unplugged the z-axis limit switch of the printer after installing 3dtouch? This may happen because 3dtouch conflicts with the limit switch.
blksilver
Re: Falesafe
Post by blksilver » Fri Apr 09, 2021 2:25 am
Thank you for your response, no I did not unplug the limit switch, but I did get the firmware with 3d touch reinstalled but it raises the z axis almost 30mm above the bed. I also made the mistake of moving the limit switch but I set it back down as far as it could go. Should I try unplugging the z limit switch and the turn printer on and back off?
