problem with firmware A10
hi all, I was updating the firmware of the A10 with the Cable and Cura ..... suddenly 2 black block lines appeared on the display.. help me
Re: problem with firmware A10
Hello, you can re-plug the LCD screen cable, there may be a problem with the cable. If it still cannot be removed, there may be a hardware problem. You can contact geeetech's technical support page for help.
- ic.jpg (320.65 KiB) Viewed 3042 times
