Hi all first post, i have a A10m and have added a chimera hotend all wirering done and attached to new mount.
Now starts my problem, have followed instruction on e3d site about setting up marlin and have also tryed a few other malin configs off net but for the life of me i cant get it to work can some nice person set me in the right direction or maybe someone who has done this let me know how they got marlin woking.
Thxs Dave
Need help chimera hotend
Re: Need help chimera hotend
Hi, Dave69, Can you provide more details about your problem?
It boils down to not being able to upload a fully functional copy of marlin, the one i have on now has no control over the hotends and if i try to heat them up i get a error telling me heating failed printer halted please reset
Hi, does the hot end of the LCD screen showroom temperature? Have you checked that the thermistor wiring is properly connected?
Yes all connections checkecked but i only have 1 hotend showing in lcd and shows room temp but cant check other 1:(
Should the lcd be showing both hotends?
I followed a vid shows he gets 2 hotends in lcd but on mine it still shows only 1 ((((
Ok guys all fixed and up and running just had to tweak a few things but got there in the end
can you send me the details on how you completed the change to the Chimera hot end. What additional wiring do I need? Do I need new power supply? I have the 2 in 2 out Chimera hot end on order...i understand i need a new mount (that is if I can print one out)...Thank you
