A10M Vref for Stepper driver
Moderator: vert
Niyoki
Post by Niyoki » Sat Apr 20, 2019 3:42 pm
For stock Geeetech A10M which Vref Voltage is the best? I checked all all five drivers is 0.8 Volt.
Under A10 Faq i found this.
1.4 Check the voltage of the motor driver and the motor connector.
Measure the voltage of the driver board, normally the value should be 0.8V-1.2V, you can put the red probe of multimeter on the potentiometer,
Newls
Re: A10M Vref for Stepper driver
Post by Newls » Mon Apr 22, 2019 3:27 am
If they are ok at 0.8 leave them there.
I'm assuming you've got the stock A598 drivers which are the noise ones. For those anywhere between 0.8 and 1.2 is good.
If you're experiencing issues at 0.8 try increasing to 1.2
If you have TMC2208 drivers (The quiet ones) then 0.8 is the correct value.
Niyoki
Post by Niyoki » Fri Apr 26, 2019 6:41 pm
Thank you for Feedback
Regards
Niyoki
Niyoki
Post by Niyoki » Sat May 04, 2019 6:37 pm
Thank you @vert ,
I changed all A4988 Vref voltages to 1.2 Volt. Everything works smooth and not more heat than with 0.8 Volt.
Regards.
Niyoki
