A10M Extruder Fans very very loud!!!
Moderator: vert
Speedy79
Post by Speedy79 » Sun Jan 13, 2019 1:45 am
Hello, i have a problem with my A10M.
The 2 Extruder Fans are soo loud and they running with 100% :cry:
It is possible to change the Firmware settings to make it quieter???
buttervonwaffle
Re: A10M Extruder Fans very very loud!!!
Post by buttervonwaffle » Sun Jan 13, 2019 4:22 am
You can just set it in your slicer software such as cura, it should be under cooling in cura, and any other software.
but if im honest these printers with the current fan setup, you almost need that 100% fan speed when you are printing. There's mods you can do to add more fans and run them slower. such as this
But I do know a lot of people have complained about the stock fans, I mean its a cheap printer, so they definitely were not gonna invest in quite fans.
So that's my advice, I personally run mine at 100% but you do what works best for you, especially if the fan noise is a deal breaker.
If something I said just helped you out tremendously you can drop a little ramen money, the coding monkeys in my basement will appreciate it - Feed them here
You can private message me if you have any questions I might be able to help.
3dralf
Post by 3dralf » Sun Jan 13, 2019 7:45 pm
I found no way to lower the Speed at cura or s3d.
Does not work.
I'll install 2 * 12V Silent Coolteks at one 24V line, cause teh A10m has 24V Fans.
Therefore i must modify Printhead or find on @ Thingiverse
buttervonwaffle
Post by buttervonwaffle » Mon Jan 14, 2019 2:41 am
I dont know about simplify3d, but it should have fan speed control, Because that's a basic 3d printer function. But cura has it under Cooling, and if it doesn't show up click the gear and search for fan speed its there I promise.
3dralf
Post by 3dralf » Tue Jan 15, 2019 1:21 pm
Problem isn't to find the FAN Control, problem is that you can not control the fanspeed even not over the display.
There is no faster or slower reaction by the fan.
Users browsing this forum: No registered users and 10 guests
