Outer wall /. inner wall connection
Using Cura 4.6.1 on A10M. Why don't I get good connection between the inner and outer wall? I tried increasing over lap and no change
- 15894216990317010083877412999227.jpg (247.9 KiB) Viewed 3733 times
Re: Outer wall /. inner wall connection
Hi,have you set the mixing ratio? Maybe one of the extruders has no material.
I am running 100% of extruder 1. No mix.
Hi,my friend.
I suggest you use repeater - host.
There are configuration files on the official website.
You don't have to worry about slice settings.
