Software to learn as a graphic deisgner
riyagdi
Post by riyagdi » Tue Jun 28, 2022 7:47 pm
As a graphic designer, there are certain software programs that you should learn in order to be successful in your field. Here are four software programs that every graphic designer should know how to use:
1. Adobe Photoshop - Photoshop is a widely used program for crafting layouts, graphics, logos, and photos. If you want to be a successful graphic designer, you need to be proficient in Photoshop.
2. Adobe Illustrator - Illustrator is another Adobe program that is used for creating vector graphics, illustrations, and logos. If you want to break into the world of graphic design, you need to know how to use Illustrator.
3. Adobe InDesign - InDesign is a program used for creating layouts for print and digital media. If you want to be a successful graphic designer, you need to know how to use InDesign.
4. Adobe After Effects - After Effects is a program used for creating motion graphics and visual effects. If you want to be a successful graphic designer, you need to know how to use After Effects.
So tho learn these software you can check out Graphic design courses in Delhi
