Good morning all
I have a problem on the Y axis.
printing is shifting!
no hard point, at the belts, pulleys ...
I think it's at the level of electronics.
I adjusted the four motors which were often hot at 1,2V, beetwen screw and ground
Is it correct??? for all motors?
thanks
Y printing offset problem
Re: Y printing offset problem
Hi,If the motor overheats,
Can be adjusted to about 1V,
Print in a well-ventilated area.
I set at 1 Volts motors, but only the Y not work...
Is it possible was down?
date on motor 27/02/2017
Is there to sold on store? because he have different fixing.
regards
regards
Hi, you can try swapping the driver board to see the situation.
Hi William, thanks for support...
I swap the stepper on mother board, but same problem.
I try to swap motor, (Pulley, screw), but power and rear fixing are not same.
At start the rotation was reverse, big worries.
Then I try to find a new motor , (this printer was a reconditioned) It work fine, but the printer suddenly has shifted, only axe Y.
Regards
Regards
Re: Y printing offset problem -update 25 March
HI
I m looking for Vref 1.2V not work
I give you more information to help me:
Drver A4988 with R200
Motor 42SHD0217-24F at current ratted 1.5 A
the vref is:
vref = 8 x 1.5 x 0.200
or
Vref= 8 x 1.5 x0.068
regards
the vref is:
or
regards
