About a month ago I ordered a Geeetech I3 Pro W as my first 3d printer. To their credit, assembly was fairly easy even though none of the included hex keys fit any of the bolts they shipped. The only weird thing was that literally everything in the box was coated in black....something.
10.0.0.0.1 192.168.1.254
I can count on one hand the number of successful prints I've managed to pull off since assembly. First the belts were too loose, easy fix I just didn't know how tight to make them. Then the belt clamp worked loose - kind of weird. Then the bed would seemingly unlevel after every print. I didn't so much fix this as got around it by installing a BLTouch which took a fair bit of work on a Pro W. Then the extruder motor cable failed. Easy to replace, but it's less than a month old. I managed to break the fan trying to disassemble the extruder which is totally my fault, however they no longer make the fan they shipped me a month ago. Now it's connected by dupont cables. Today the extruder stopped extruding entirely, again. Filament had oozed out the top of the heat block and clogged the nozzle. The threading came off the nozzle disassembling it though, so that's a loss.
Is this just par for the course with 3D printer kits or did I just order the wrong brand? Just a bit frustrated that so far I've managed to print a Switch game case and nothing else.
Geeetech i3 Pro W horror stories
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
