X-Axis Belt Problem
Salty Stump
X-Axis Belt Problem
Post by Salty Stump » Sat Nov 23, 2019 12:38 pm
Recently i noticed that my X-Axis wasn't moving all the way over, so i tried moving it manually and found that moving it to its maximum value only made it go about a quarter of the way. If someone knows whats going on please tell me. :)
Footage of the problem: https://youtu.be/cqTVb_BLQQI
Re: X-Axis Belt Problem
Post by William » Sat Nov 23, 2019 1:43 pm
:D Hi, You can check if your x-axis limit switch is properly connected to the motherboard.
You can then connect the printer to your computer via USB and use the Repetier Host's manual control input M119 to check the status of the limit switch.
For details, you can refer to this: http://geeetech.com/forum/viewtopic.php?f=17&t=60927
I hope this can help you.
