Layershifting x-axis
realmrcool
Post by realmrcool » Tue Aug 27, 2019 5:04 pm
Hello, got some layer shifting all of the sudden.
The printer was running smoothly after two hours the layer of the zylinder shifted.
Now its shifting every print from the beginning making a clicking sound.
I tried fixing the x axis but still the same...
(Fastening belt, readjusting the grabber to the motor shaft)
Kind regards Fabian
Re: Layershifting x-axis
Post by William » Tue Aug 27, 2019 5:24 pm
Hi, You can check the following aspects:
1. Check the belt tightness of each shaft and make appropriate adjustments;
2. Check whether the bearing and the pulley are issued (the card can be lubricated for lubrication);
3. The printing speed should not be too fast, the reference range is 30-60mm/s;
4. Adjust the driver board voltage (0.8-1.2V).
I hope this can help you.
realmrcool
Post by realmrcool » Tue Aug 27, 2019 6:35 pm
It needed some lube. THX!
WORKS GREAT AGAIN :)
i used wd40 which is not the best choice i guess.
What oil is reccomended for maintainance?
Ty again bestregards Fabian
Post by William » Tue Aug 27, 2019 6:39 pm
Hi, Regarding the lubricant, whichever is fine,
Just need the bearings and pulleys to lubricate a little, put the operation and issue the card.
