Z-Axis won't move
Mattes83
Z-Axis won't move
Post by Mattes83 » Wed Jan 02, 2019 7:22 pm
I just assembled my prusa i3 w and tried to move all axis.
X and Y axis move fine, z axis doesn't move at all. The motors both move fine, but when I tighten the threaded rods on them, they don't move and only make noises.
Can anybody help me?
What could be the error?
Mattes83
Re: Z-Axis won't move
Post by Mattes83 » Wed Jan 02, 2019 9:50 pm
OK, I found a solution myself: the screws in the z-axis nut where too tight. I loosened them a little bit, and now it works.
I don't understand why. Can someone explain me, please?
Nick1989
Post by Nick1989 » Wed Jan 02, 2019 11:38 pm
Good luck. I got wrong Z axis couplings and I'm still waiting to hear about that days later...
I did read somewhere that one of the pictures was wrong in the instructions for assembly eith regards to the Z axis stuff. I'll see if I can find it again
yorkie1
Post by yorkie1 » Tue Feb 05, 2019 5:06 pm
I had the same problem but with me it was the threaded rods were dry but after a bit of lubrication everything works fine all i have to do now is a test print some help on this would be appreciated. yorkie1
JakobM84
Post by JakobM84 » Wed Sep 04, 2019 11:22 am
I am having the same issue. The stepper motors both turn when I have the coupling loose from the threaded rod but when I connect the coupling It sounds like they are trying to move but the threaded rods don't even look like they are trying to turn. I lubed the rods up and they turn pretty easily when I turn them with my hands. I havent busted out my bubble level yet but I would think you would at least see it try to move.
