Only one extruder visible from LCD menu
luca.aless.2011
Post by luca.aless.2011 » Fri Jan 24, 2020 5:56 pm
I just assembled the I3 Pro C
Everything works fine except for this:
In the LCD menu Prepare/move Axis I can visualize only one EXTRUDER and not EXTRUDER 1 and EXTRUDER 2
When I try to move the Extruder from the menu, both extruders works at the same time
I'm controling both extruders together.
It seems as if the firmware is set for one extruder only
From the menu I can see and control the temperature of two nozzles, so it seems the firmware loaded is the correct one for two nozzles but probably for only one extruder
Extruder 2 rotates opposite, so I cannot load the filament
How can I get the printer to recognize two extruders and to control them separately?
Had anyone had the same issue?
Re: Only one extruder visible from LCD menu
Post by William » Thu Jan 30, 2020 6:41 pm
Hi,The two extruders are on the same horizontal line, and you can observe where the extruders are located.
