X-Carriage Replacement
Mr.Hotwire
Post by Mr.Hotwire » Mon Jun 24, 2019 9:23 am
Good day,
I purchased an I3PC, and have found that the bearing clamps on the X axis have cracked. These are obviously printed parts, perhaps the previous owner has swapped them out and printed using PLA.
Has anyone had experience with replacing them, and what filament did you use to do so? Do you have a link to the STL's that you used? As there are a few on thingiverse I am not 100% sure which are the right ones.
Re: X-Carriage Replacement
Post by William » Mon Jun 24, 2019 9:44 am
Hi, you need to loosen the belt and then install the belt clip and adjust the belt to a moderate degree of tightness.
Mr.Hotwire
Post by Mr.Hotwire » Mon Jun 24, 2019 10:46 am
The parts that I am talking about are these parts :
https://www.thingiverse.com/thing:2237383/files
GAQ
Post by GAQ » Fri Jul 05, 2019 10:00 pm
Hi 'Mr.Hotwire'
How about replacing with these ?
It has to be a better solution ?
https://www.geeetech.com/upgraded-metal ... p-970.html
Gerry
Mr.Hotwire
Post by Mr.Hotwire » Tue Jul 09, 2019 3:06 am
Good idea, I will look into it. I have printed off a set, But I will be doing some modifications to them to help make them more stable.
Users browsing this forum: No registered users and 5 guests
