Turning on heaters causes 15A fuse to blow
chrisnasulea
Post by chrisnasulea » Mon Jun 10, 2019 4:41 pm
Hello everyone,
I've just moved to a new house and brought my I3 Pro C with me. It was working perfectly before the move. The first time I tried to turn it on after hooking everything up it blew one of the 15A littlefuses on the board. I replaced the fuse, tried to turn on the heater for extruder 1 manually from Repetier Host and the fuse blew again.
I looked at various forums but I couldn't find anything useful.
Any thoughts?
Re: Turning on heaters causes 15A fuse to blow
Post by William » Mon Jun 10, 2019 4:54 pm
Hi, you can check if 1.the wiring on the motherboard is correct.
                             2. Whether the thermistor is detached or caused by poor contact.
chrisnasulea
Post by chrisnasulea » Mon Jun 10, 2019 5:55 pm
The printer was moved reasonably carefully from one apartment to the other so the wiring on the motherboard seems undisturbed.
Which thermistor are you referring to? There seems to be a bit of black colouring on the plastic surrounding the wires coming out of extruder 2. Maybe it was not there before, maybe it was.
Post by William » Mon Jun 10, 2019 6:15 pm
About the wiring of the hotbed and extruder and thermistor on the main board.
Post by _kaktus_ » Thu Jun 20, 2019 9:35 pm
Hi chrisnasulea.
:D
I haven't seen you here in a long time.
It's a pity you only look when you're forced to.
William is right about the 15A fuse circuit, there must be a short circuit somewhere.
Your observation can be helpful in diagnosing a fault.
First try to disconnect this circuit and check whether the fuse will be blown again. If not, you already know where to look for a fault
