Upgrade: E3D-V6 + Titan + 3D-Touch
flat-jack
Post by flat-jack » Sat Mar 09, 2019 9:06 pm
I designed a modification to install a E3D-V6 Hotend + Titan Extruder for my I3 A PRO.
Wanted to get rid of that heavy MK8. Also added a cooling fan and support for 3D-Touch.
NEW VERSION :!: :!: :!:
You can find it here: https://www.thingiverse.com/thing:3487000
Maybe someone finds this helpful.
Thx
Re: Modification for E3D-V6 + Titan [Bowden Style]
Post by William » Tue Mar 12, 2019 11:53 am
It is a good modification for A PRO.
Thanks for your sharing!
Collier57
Re: Upgrade: E3D-V6 + Titan + 3D-Touch
Post by Collier57 » Fri Aug 06, 2021 6:24 pm
For a standard Titan Aero configuration, the maximum recommended temperature is 285°C when hot tightening you should heat the Titan Aero up to 285°C, and when changing nozzles you should heat up the hotend to 285°C.
