Fanduct for Prusa i3 Pro and Pro B for better resolution
dodonash
Re: Fanduct for Prusa i3 Pro and Pro B for better resolution
Post by dodonash » Wed May 06, 2015 5:17 am
i have same proplem i need a stl file for fan for geeetech prusa i3 pro i print the one is attat put it is rong
jgvonk
Post by jgvonk » Wed May 06, 2015 6:18 pm
You alsow need to print the carridge of the Pro B to use the fanduct.
JETNC
Post by JETNC » Tue Jul 21, 2015 3:46 pm
I'm new to printing, I've only made some 10mm test cubes. How does the air blowing onto the print help the process?
I have a dual extruder i3 Pro C. It seems like my fan only cools the back of the two motors. .....
Sherry
Post by Sherry » Tue Jul 21, 2015 4:49 pm
JETNC wrote:I'm new to printing, I've only made some 10mm test cubes. How does the air blowing onto the print help the process?
regarding to i3 Pro C,the fan mounted to extruder is for cooling extruder .so it could not used to cool printer.
JETNC
Post by JETNC » Wed Jul 22, 2015 1:56 am
Is the fan very efficient for cooling the extruders if it's mounted at the back of the motor?
Also, at what point during the print process should the fan cool? Is it off and on to regulate the extruder tamp as needed?
Sherry
Post by Sherry » Fri Aug 07, 2015 3:06 pm
JETNC wrote:Is the fan very efficient for cooling the extruders if it's mounted at the back of the motor?
do you point to PWM fan? it is controled by g-code.
