I had problems to communicate my Arduino UNO R3 + GSM SIM900 Shield, the error is:
GSM Shield testing.
DB: NO RESP
DB: NO RESP
DB: NO RESP
ERROR: SIM900 does not answer. Check power and serial pins in GSM.cpp
status = IDLE
I've changed the values in the file Tx Rx GSM.cpp and nothing external power and is still not working.
Can you help with my problem?
Is there a library or some way to communicate the two shield?
Problems of communication Arduino UNO R3 + GSM Shield SIM900
- techsupport
- Site Admin
Re: Problems of communication Arduino UNO R3 + GSM Shield SI
Hi, friend
I am sorry for provided less information.
You can follow the WIKI http://www.geeetech.com/wiki/index.php/ ... PRS_Shield .It is easy ,please read carefully.
If any problem ,please tell me.
Youes sincerely
techsupport
Youes sincerely
techsupport
Email: forum@geeetech.com
Now connect the two Shield, I'm testing some AT commands, the problem right now is that I can not log into my network operator (DIGITEL VENEZUELA)
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
- techsupport
- Site Admin
Hi ,friend
I am sorry for late reply.
I can't sure the VENEZUELA card you used is suit for the GSM Shield SIM900 .
Have a SIM card to test the GSM Shield SIM900?
Yous sincerely
techsupport
Yous sincerely
techsupport
When I put the command AT + COPS =? I get a single network
AT+COPS=?
+COPS: (1,"movistar","movistar","73404"),,(0,1,4),(0,1,2)
OK
how to register the gsm network operators?? ( DIGITEL)
My SIM card is vendor DIGITEL...
Please help me!!!
AT+COPS=?
OK
Please help me!!!
- techsupport
- Site Admin
Hi ,friend
I am so sorry for the late reply.
I analyse your problem , I think the signal of SIM900 is too weak possibly.
Do you test the signal (AT+CSQ) ?And check the connction of the antenna.
You can put the command AT + COPS ? not AT + COPS =? to check if the card connect a network operators.
Yours sincerely
techsupport
Yours sincerely
techsupport
My SIM card is from the network operator DIGITEL GSM operates in the 900MHz band, the signal level is:
AT + CSQ
+ CSQ 12.5
If my Shield GSM SIM900 is quadband, because it can not register my mobile network operator DIGITEL??
AT + CSQ
+ CSQ 12.5
- techsupport
- Site Admin
Hi, friend
The signal of SIM900 is ok. But it is a big trouble that your SIM card is from the network operator DIGITEL GSM operates .I haven't too much information about the
DIGITEL GSM. I just find the http://arduino.cc/en/Main/ArduinoGSMShield It is important about the Notes on the Telefonica/Bluevia SIM included with the shield
I find VENEZUELA in these countries.
Yours sincerely
techsupport
Yours sincerely
techsupport
== www.crosswordchamp.com ==
