Hi Community,
i updated the Firmware of my Rostock 301 with easyprint. The firmware number is also shown in the printer menu. Everything ok so far.
BUT: Wehn i print something (Data from SD wich worked before// just a simple 20mm cube) its suddenly just half the size!
Does anyone know what i have to change in the new firmware??
Thanks in advance.
Firmware change to V1.0.04 prints half the size
Re: Firmware change to V1.0.04 prints half the size
Have you checked the steps/mm of three axes?
LCD->Control->Motion->stepps/mm.
I found it... the bed is measured different in the new firmware. So you also have to clear the EPROM. that the values are set.
In this forum I see the last firmware for rostock 301 is 1.0.03 you write about 1.0.04 Is this ok?
There is a software and firmware repository.
All new products are introduced there first.
I see the file you are asking about there.
Ok,,,,, thanks!.. can I read what changes in this new versión?.
I would also like to know that.
