Irregular temperature increase
Posted: Thu Oct 08, 2020 1:15 am
by rezjat
Hi.
Since some weeks ago, I observe that when starting temperature increase towards its target, from around 150ยบ it start to show a quite irregular curve (up and down values), instead of a smooth curve as It was before.
But once it gets the target (in a very irregular way), it works normally...
Any suggestions? Is it a signal of thermistor starting failing? I disconnected connectors at main board and connected again but no differente...
Thanks a lot!
Javier
Re: Irregular temperature increase
Posted: Sat Oct 10, 2020 2:57 pm
Hello, it may be that the thermistor is not too sensitive, but if it can be used normally, don't worry. :D
