reduce printing speed in easyprint3d
Posted: Tue Jan 21, 2020 1:50 pm
by lukorely
hello I have the prusa i3 pro b and I have layers shift in the Y axis, according to lei it is because of the print speeds so I would like to reduce the speed and try, Or does anyone know the solution to that problem? thanks
Re: reduce printing speed in easyprint3d
Posted: Tue Jan 21, 2020 2:11 pm
Hi, about layer movement,
You can check:
1. The tightness of the belt;
2. Whether the bearings and pulleys are issued with cards and lubricated with lubricants;
3. Whether the drive board voltage is in the normal range: 0.8-1.2V;
You can refer to the print speed adjustment in easyprint:
- DLPVK`(Q[LQT9L)}SYEGVG1.png (54.07 KiB) Viewed 4412 times
Posted: Wed Jan 22, 2020 2:23 am
by lukorely
hello thank you very much I could solve the problem by copying your configuration, but I have another problem, I am printing the xyz cube and in the part of X it cuts a part and it is not a perfect cube
Posted: Wed Jan 22, 2020 4:00 am
by edvingrozni
Hello Lukorely,
What tipe of filament you use?
Did you calibrate feed rate of filament?
Posted: Wed Jan 22, 2020 7:50 am
by lukorely
I use PLA, I don't understand what you mean by speed, but that issue already solves it (the layer shift)
