Prints stopping halfway through!!
jasminemendonza
Post by jasminemendonza » Thu Aug 22, 2019 7:36 pm
Everything seems to be working more or less perfectly now, but my extruder stops working about 20 mins into any print. Is this a common problem? How do I fix it?
This was PLA at 200 degrees, which seems to work for a while.
Re: Prints stopping halfway through!!
Post by William » Fri Aug 23, 2019 9:28 am
Hi, You can check if the thermistor wiring of your hot end is fully connected.
Are you printing via sd card?
Or use USB to connect to the printer and slice software for printing?
Printing via sd card maybe your motherboard problem;
Printing via a USB connection may be caused by hitting the USB line midway.
I hope this can help you.
Users browsing this forum: No registered users and 1 guest
