Prusa i3 pro B Power supply + GT2560 dead ?
P0pR0ock5
Post by P0pR0ock5 » Mon Mar 19, 2018 4:26 pm
I've buyed my first 3D printer and it's a Geetech !
The build was easy and everythings is well explained with the instruction manual and the videos.
But, i got an issue with the electronic parts.
I've wired everything correctly (checked twice, wired once) but after turning on, the power supply make a weird noise and the small LED on it stopped shine.
So for troubleshooting i've check the topic on your forum.
- fuse OK
- launching the power supply disconnected from the load(GT2560) : 12 v
- Connected on the GT2560 : 0v
After that i've tryed to use my lab power supply and, same problem, the GT2650 does not start ( no LCD, no Light ).
- The power supply give 20A at 12v
- Power supply disconnected from the load (GT2560) :12 v
- Connected to the GT2560 : 12V
For testing my GT2560 board :
- Remove all the wires
- Remove stepper drivers
- Connect on the PC : Not detected by Arduino IDE
- Checked in dmesg (im on linux) NOTHING
My guess :
Power supply does not support the load - > Dead ?
Even with external power supply, the mainboard is not working -> Dead too ?
My question : What can i test ?
I've ordered this printer from GEEEtech shop on ebay, can i get replacement parts ?
Re: Prusa i3 pro B Power supply + GT2560 dead ?
Post by William » Mon Mar 19, 2018 7:52 pm
You should contact sales to sending you a new mainboard
P0pR0ock5
Post by P0pR0ock5 » Mon Mar 19, 2018 9:09 pm
You think that the only problem here is the mainboard ?
Should i contact the sales by Ebay or using this website ?
P0pR0ock5
Post by P0pR0ock5 » Mon Mar 19, 2018 11:09 pm
Should i contact the support via ebay or via this website ?
Producer_Phil
Post by Producer_Phil » Tue Mar 20, 2018 3:55 pm
Contact the support via email, it might take them some time to respond, guess they are pretty busy.
I just had a faulty board and ordered a new one. My old one would not power up when plugged into my Usb port.
The new one just goes on straight away.
Hope this was somehow helpfull for you
GJRTimmer
Post by GJRTimmer » Wed Mar 21, 2018 2:48 am
Either directly through the website or your reseller if you used one.
Had a similair problem, after providing some tests they will make you do with a volt meter, they shipped me a new board.
Now printing very happily. Currently upgrading the Hot Bed to a MK3 Black Alu, and 24v.
Hope this helps.
