GeeeTech Rostock Mini G2S Pro Concave Offset
Re: GeeeTech Rostock Mini G2S Pro Concave Offset
Post by William » Mon Jan 22, 2018 4:18 pm
You should increase the voltage of A4988 driver board
(You can find the way how to adjust the voltage of A4988 at forum )
skymen
Post by skymen » Mon Jan 22, 2018 4:43 pm
I have cleaned the gear from the motor on the top. Still not working as it should be.
If i press the handle a little up. The filament goes how it should be.
Anyone a tip??
skymen
Post by skymen » Mon Jan 22, 2018 11:50 pm
[quote=William post_id=82182 time=1516609093 user_id=51382]
[/quote]
The pressure of the filament was good. Sinds yesterday the gear doesnt pick the filament well.
If i lift the handle on the top a little, the filament goes as it should be.
This have nothing to do with the voltage right???
Sorry for the bad english, i hope you all will understand :$
Post by William » Wed Jan 24, 2018 1:42 pm
Maybe you should check if the screw of the gear has been firmly fixed
skymen
Post by skymen » Thu Jan 25, 2018 2:52 am
thanks for all the reactions, i have found the issue
it was a part next to the gear, the plastic what was holding the roller was broken.
dont know if it is the correct name.
thank youu all
