Geeetech a30 Not extruding filament
sirikonta
Post by sirikonta » Fri Jan 21, 2022 3:48 pm
Feeder is Not pushing the filament
Hi guys. I have a little problem with my 3d printer. When i‘m loading or unloading new fillament the printer pushes it fine through the tube. But when i start a print the filament doesn‘t move anymore. The Motor with the gear is rotating but the feeder wheel is standing still. Any suggestions? Ps the Printer is a Geeetech A30.192.168.0.1 router login 192.168.l.l
lamonnajackson93
Re: Geeetech a30 Not extruding filament
Post by lamonnajackson93 » Thu Jan 27, 2022 8:32 pm
A lot of factors could be causing the filament not to extrude from the printer. Make sure that you are loading the filament properly, and check your nozzle for any blockages. If it still won’t extrude, double-check your power source and see if it is getting hot or warm at all. Also, ensure that you have enough room for the stepper motors to move freely inside their housings. It is time to check what is the best essay writing service because I need to get my essay written on time.
