A30 blank screen
Re: A30 blank screen
Post by William » Mon Jun 08, 2020 9:56 am
Hello, you can refresh the firmware according to this document,
how to update ui file1.rar
(24.02 KiB) Downloaded 298 times
the Sd card should be inserted into the card slot at the back of the screen.
blacklabs
Post by blacklabs » Mon Jun 08, 2020 10:07 am
I thought i was supposed to use the version of firmware that is posted. See my screenshot of the successful LCD firmware update. I have tried the SD slot version many times. That does not work either. I the config.txt file and the bin along with system folder and still blank screen looks Black. Ready to try something different like ST-link that way I know it is burning it to the STM chip. See my previous request.
Post by William » Mon Jun 08, 2020 10:53 am
hi, you mean the bootloader?
LCD_bootloader_V1.0.rar
(22.61 KiB) Downloaded 320 times
blacklabs
Post by blacklabs » Mon Jun 08, 2020 11:06 am
Thank you. Is this bootloader hex file for the LCD screen that is in the TOP of the image you posted?
Do I need to jumper the Boot0 jumper on the LCD when using the boot loader?
Post by William » Tue Jun 09, 2020 9:20 am
Hi,there is no need to use the boot loader.
blacklabs
Post by blacklabs » Tue Jun 09, 2020 9:42 am
OK then how to I get the display to work. I have updated the firmware on the MB and the display many times using the 2.0 tool and the tool reports successful but the display is still black. I have put the config.txt file, bin file and the system folder on the SD card many times and put the SD in the side of the display and that does not work either. I get no response when I put the SD card in the slot and apply power. I even deleted all files from the SD cards, then formatted the SD cards FAT32 and tried that again and still nothing. I have a black display.
What should I do?
Post by William » Tue Jun 09, 2020 11:12 am
Hi,need to connect first: VCC of ST LINK is 5V. And please pay attention to GND and VCC, look at the color of the line (pictured). You can use the st-link brush to guide when the line is connected correctly.
