Drucker wirft während Druck Filament aus
Vlad_dracul
Re: Drucker wirft während Druck Filament aus
Post by Vlad_dracul » Wed Jan 22, 2020 8:20 pm
I print the same g code 3 times 1 is good 2 failed at different layer heights.
I tested to print with SD card same sometimes it work sometimes not.
But my extruder motor is really hot... I think over 70°C.
Vlad_dracul
Post by Vlad_dracul » Wed Jan 22, 2020 8:21 pm
How I can use Marlin?
Post by William » Thu Jan 23, 2020 9:11 am
:D Hi, If you print for a long time,
The electric machine has overheated,
You can print in a well-ventilated area,
Or make appropriate adjustments to the drive board voltage.
Can the test files in the SD card be printed normally?
Vlad_dracul
Post by Vlad_dracul » Thu Jan 23, 2020 10:53 pm
Where the Printer stay it have 19°C.
The Extruder driver runs with 0,5 V. How low can i adjust?
Yes, short prints runs well.
All about 3 Hours are high risk.
