ABS / PLA does not stick to the table, I do not know what to do.
Do I have to put glue or something?
Or some setting that are not correct?
My printer is an A30.
table does not stick
Re: table does not stick
The work table (hot bed) must be clean and properly warmed up.
You can buy something similar:
https://www.ebay.com/itm/3D-Printing-Bu ... 8183943?ss
I use something that nobody has come up with here ;-)
[attachment=0]lakier_do_wlosow.jpg[/attachment]
The cost is small, the effectiveness of good, smells good, it is easy to wash off with clean water. ;-D
- hair spray
- lakier_do_wlosow.jpg (299.75 KiB) Viewed 6440 times
Have you leveled your printbed correctly?
It's really important to do an manual leveling procedure, fit a standard A4 paper between the nozzle and the bed.
Also, what temperature is your bed during print? And what nozzle temp do you use?
There are many possible reasons for a print not sticking to the bed.
