GiantArm D200 3D printer
Outback1
Re: GiantArm D200 3D printer
Post by Outback1 » Thu Jul 18, 2019 8:12 pm
update had a friend come around with a galaxy S10 and he gets the exact same message as i do serial number dosent exist anyone else have this issue ?
Post by William » Fri Jul 19, 2019 10:18 am
Hi, you can view your serial number through the About in the screen.
Outback1
Post by Outback1 » Sun Sep 01, 2019 6:38 pm
Hi the serial on the side and in the screen are the same but my app is saying it dosent exist :( i have now installed drivers for my Macs and can print via usb so all good but today i used my mac pro forgot to setup the program properly :( was in a rush and destroyed the extruder tip :( where is the best place to buy spares ? i think the one in it was a 0.5mm
Post by William » Mon Sep 02, 2019 9:10 am
Hi, Are you referring to the broken nozzle?
Its standard diameter 0.4mm caters to 3D printing fanciers’ regular need.
OldSputnik23
Post by OldSputnik23 » Sat Apr 11, 2020 10:57 pm
I am having the same problem where it is saying that the serial number does not exist.
Post by William » Mon Apr 13, 2020 9:22 am
Hi, Are you referring to 3d wifi
You can check if the serial number is attached to the back of the wifi.
topcar
Post by topcar » Sun Apr 10, 2022 6:07 pm
The 2022 Lotus Emira version is powered by a supercharged version of the 3.5-liter V6 2GR-FE engine from Toyota, which produces 395 hp and 420 Nm of torque.https://www.gtopcars.com/makers/lotus/2022-lotus-emira/
