Page 1 of 2
E180 Hardware and Software Upgrade
Posted: Tue Nov 12, 2019 4:38 am
by tokar2222
Hi all
I start upgrade my E180 And technically I did:
1: Hot end CR10 (PID data from another user)
2: Driver TMC 2208 ( Wait for solution of couple issue)
3: Hotbed (Just hardware for now, I found very nice plate 120x120)
4: Full maintenance inc. belt, bearing, lubricante etc
As I understand our mainboard is compatible with hotbed. It have all of conector and places where to install hardware. So only software stopped my.
Im looking for somebody who known how to play with source code in IAR or Eclipse
1. To Active hotbed function
2. Force E180 to accept AutoPID Tune in RepiterHost
3. Increase max temp of hotend to 270
Any suggestion and every help needed
hardware is time consuming and I'm not the best with computer
Re: E180 Hardware and Software Upgrade (Need Help)
Posted: Tue Nov 12, 2019 9:30 am
Hi, E180 does not have a hot bed.
If you change it, it may not match the function on the motherboard.
The firmware it comes with is not Marlin firmware.
Posted: Tue Nov 12, 2019 3:33 pm
by tokar2222
Mine allredy have hotbed, but I would like to controlled by build in software. I can do manual control board but that's gonna by last way
About AutoPid I allredy known its not gonna work
Posted: Fri Nov 15, 2019 5:38 pm
by apak
don´t bother. Get rid of stock board and display.
You could compile a E180 heated bed firmware from github, but you can not do it with the screen FW.
Board github is not been updated in more than a year, screen fw is not available, marlin 2 is not yet suported and not soon to be.
I just change electronics and everything works perfectly since ever.
https://www.thingiverse.com/thing:3680288
Posted: Fri Dec 06, 2019 10:02 pm
by tokar2222
After not fair battle I decide to order skr1.3 + chimera hotend, and few extra parts to print in PLA without switching anything
Do you have a Marlin for e180? That will be awesome, at least for first run.
Thanks in advance
Posted: Sat Dec 07, 2019 5:26 am
by apak
Posted: Sat Dec 07, 2019 6:56 am
by tokar2222
That's mine direction, with few small exceptions
Posted: Sat Dec 07, 2019 9:05 pm
by tokar2222
My SKR set just arrived, so lets get this party started
Posted: Sat Dec 07, 2019 11:35 pm
by tokar2222
We will see if I can
Time will verify. If I not gonna replay anymore that's mean E180 is in garbage
Posted: Fri Dec 13, 2019 6:08 am
by apak
skr works flawless, but GTM32 smartto is an open source proyect that looks abandom. TODAY it´s been release A30M and A30Pro firmwares, but NO source code, not any update on github.
SKR updates their software daily, so GTM32 it´s a ferrari board with a lack of source code, and support from geeetech.
My E180 is now with skr, marlin 2, v6 hotend, heated bed, and many things that geeetch could have done, but didn´t
